RCU Forums - View Single Post - Jato 3.3 Idle problem
Old 08-26-2012 | 12:25 PM
Rac3rX
Default RE: Jato 3.3 Idle problem
""""""""""Low-Speed Fuel Mixture Adjustment
The low-speed mixture is always set after the high-speed needle is
correctly adjusted. The low-speed mixture is set using the “pinch test”:
1. Once the engine is warm, do several high-speed runs to confirm
that the high-speed needle is set correctly.
2. Bring the vehicle in and pinch closed the fuel line going into the
carburetor (use the engine shut-off clamp). The engine should run for
2-3 seconds, speed up, and then shut off.
3. If the engine runs longer than 3 seconds, then lean the low-speed
needle 1/16 turn, make several more high-speed runs, and retest.
4. If the engine shuts off immediately without speeding up, then richen
the low-speed needle 1/8 turn, make several more high-speed runs,
and retest.
When the low-speed needle is set correctly, the engine’s throttle response
should be very quick, even to the point of making it difficult to keep Jato
from doing a wheelie when you accelerate!""""""
