ORIGINAL: 1sgt
Richards,
I'm doing the same conversion. I plan on replacing the fixed suspension with shocks off of a HL Pershing. I know it won't be protypical as they are about twice the size but I think it will give it some nice working suspension. I also had planned on replacing the gun tibe with brass ( do you have any pics?) I plan on cutting the muzzle brake and recuperator off and drilling through them and using them on the brass barrle. Did you do the same ?
Jim
Jim, thats exactly what I did with the barrel. I cut it off where the barrel met the recuperator. I carefully drilled through the recuperator, I then opened it up enough to insert the brass barrel. You will also need to drill out the mantle, it's solid also. I used plastic weld to hold it in place. I would like to see how your planning on doing the suspension. I'm definitely interested.
