Ok you experts,
I am using a CC80HV, HACKER A-60-7S-V2 and started with a 20.5-14 APC PROP. I am waiting on my castle Link cable to arrive, so I can check the numbers.
This is what I experienced running the set up on 10S-5000 set up. When I go to full throttle the engine runs for about 10 seconds and shuts off, if I bring the stick on the TX back to the idle position and start to advance the throttle it's fine through out the throttle range once again. I ended up lowering the control point in the ATV's from 135% down to about 65% to eliminate the motor from kicking out (and thats' right on the thresh hold). Am I over AMPing the ESC? I didn't tach it yet either, but I know it's turning the crap out of the 20.5x14 (scary). I checked the trouble shooting guide and it really dosen't have an explaination for it.
I was wondering if anyone else has experienced this? I'll know more when the cable gets here tomorrow. In the mean time I figured I'd share this with everyone and get a head to a potential solution.
bholsten
