RCU Forums - View Single Post - Control Throws Adjustment
Old 08-27-2012 | 04:04 PM
JohnBuckner's Avatar
JohnBuckner
Default RE: Control Throws Adjustment
ORIGINAL: chasni
>Plz look at the pictures. Elevator movement is restricted by the rudder. Is this suppose to happen
chasni the amount of the up elevater throw when it connects with the rudder is all the throw you need and in fact I would reduce the down throw to a similar degree in the transmitter if it has that capability. If not I would use a hole further out on the elevator at the elevator control horn or move the pushrod in to a closer hole at the servo then recenter the neutral.
John
