RE: New pattern ship recomendation
I built the Vanquish at the beginning of this thread with the silver bullet. The ESC wasn't available at that monent, so I used the Castle. The Torque works fine. The HiMax has more power for virtualky the same cost. The Torque does work and I am sure the Airboss ESC does as well. You can use cheap 10s packs (dual 5s) and it will work fine. If you read the beginning, you will see that I intentionally didn't use the latest and greatest stuff. I used good, but economical stuff. As I did in the thread, I would definitely use a separate receiver battery. When you invest this much in a plane, the cost of a little redundancy is minimal.
Arch
