RE: PT-311 (1:12 Scale) 6-Foot RC Electric Boat Model
Guys,
Looking carefully at the Specifications of both the TRAXXAS ESC and that of the PRO BOAT 50-AMP ESC, I am leaning to use the PRO BOAT because I will be setting up my model with a Separate Battery for the 2.4G Receiver and for the large Servo.
The PRO BOAT has a 1.0-AMPERE BEC @ 6-Volts and since I will be using 12-Volts then, the BEC output will be even less. I certainly do not want to lose my model in the middle of a lake so, I am opting to use a separate RX Battery with a switch harness.
Good nite!
Carlos
