Hey Chris,
Yeah I understand that from owning and operating an electronics based security company. Usually the vendor on the other end will not take the time to verify the date stamp. You get what you get. I use to visit batteries plus and build my own packs and purchase batteries , because I could check the dates, etc. I will order my batteries from you. I will need to run the lighest packs I can and still get throught the programs without hurting the batteries. Right now I am at 10.75 lbs with my True RC 5000/25C packs on both planes. The Rhino's I don't like, never seemed to have the same power as my True RC's did.
I have loaded the graph data. (Low Voltage cut of was the problem). I used your link to re-program the device. I will try it again with the throttle restrictions removed.
