RCU Forums - View Single Post - Goldwing 50cc Pitts Python V3.
Old 08-28-2012 | 08:05 PM
  #180
Mustangman40
Default RE: Goldwing 50cc Pitts Python V3.
Well I am pretty much screwed on changing the location of the elv. servos, gotsick of messing around and went to move them and I can't.. Above the servo locations is a stringer and the deck of the fuse, if i cut into it, the whole back end would beweak.. The only choice now is to cut off the horn and go with a bolt type horn, I will make that decision after a few flights...
I made the top wing one piece, the 3 piece stock design was weak and mine didn't line up for nothing. There are some pics back in this thread showing the gap i would have had...
Any how, I made hatches on the bottom of the center section to make my connections at the field.. They are held in with magnets and will stay attached to the wire running down the strut.. I picked up some 3/4" yellow shrink tube to attach the wire to the strut, it will work like a charm and you won't see it inless you are looking for it...
ID:	1796260   Click image for larger version
ID:	1796261   Click image for larger version
ID:	1796262   Click image for larger version
ID:	1796263   Click image for larger version
