RE: Ripped out tail gear
I've repaired the same thing by ; taking the piece that came out & slightly, slightly, sand orcarve it just a LITTLE smaller; then coat it with 30 minute epoxy, slide it in the hole it made. You let it set up & walla, no change in handling on the ground or in the air !!!!
