Hi,
I am flying an Integral with the Himax 6330-200 motor and the Castle ICE2 80HV regulator.
The Integral is a little heavy (5,2 kg) so I need as much brake as possible for the downline manoeuvre.
Setup is:
20C batteries from Zippy. The blue ones.
6330-200 with a 20,5x14 APCe prop
ICE2 80 HV ESC, latest beta SW
I have used the manual from Himaxx for the recommended setting, but changed the brake settings to 50-60%
I get squeeks from the motor - that tells me that timeing are not correct - when I add power after a dive manouvre (the Z or a reverse top hat)
Can you reccomend a setting on the ESC that most probably should work? What settings do you use for the -210 motor?
Looking forward to a quick reply!
brg
Øystein Bach
Norway
ORIGINAL: rix
I also use the Castle HV80 V2...
