RE: Throtle Spring
If you set up the linkage properly servo torque of a standard servo is more than adequate with the spring as issued. Leaving the spring in place puts a small load on the linkage and removes all play. The spring closes the throttle in the event of a linkage failure. I can not think of any good reason to remove or alter the spring.
