RE: RC Guys Super Decathlon coming
Paul
Yah,,I use a fuel dot not a valve. Standard 3 line set-up only with larger diameter tubing.
Have Sullivan large bore stopper and cluck and supply lines up to a inline filter then the smaller line to the carb. Maybe I should go all the way with the large line? I had never heard the point about large bore tubing on the crankcase vent. That's easy to do.
Thanks!
Scott
