RCU Forums - View Single Post - 55AX mid throttle issues, fixed I think
Old 08-31-2012 | 03:35 PM
napacp
Default RE: 55AX mid throttle issues, fixed I think
just so you know i to have been having the same problem went thru 22 dead stick landings but its in a saratoga and always gets back to the field tried everything you did even the f plug suggested by a old timer but still died i cant believe how good she runs for three minutes then just shuts off like a kill switch i did fix the problem though after replacing all fuel lines and clunks and filters and finally a new tank complete from hangar 9 i had bought two engines from tower so i finally switched engines and guess what 33 full flights and not one problem im sending the 55 back as this is being writen hope they can find the problem
        rick nunes
