RCU Forums - View Single Post - Let's see your work shop!
Old 09-02-2012 | 04:54 AM
  #841
1wolf
Default RE: Let's see your work shop!
Dax
The size of kits you intend to build will help dictate your layout. Small kits can be done on a small bench against a wall while giant scale kits are easier on a bigger table located so you have access to all sides. The bigger you intend to build the more "free" area you will need to move things around. I would put the bench where you want it then place everything around that. Just my 2 cents.
