RE: Throttle Spring vs Servo Current
Glow engine's are made that way because we use rod's. Gas engine's are not. The spring is, as stated before, normally on an engine in a weed eater, chainsaw, edger, etc. etc. Those do not use rod's for throttle, they use cable's and the spring is for return to idle. The spring is also, by design, a shim. It does play a role in keeping the butterfly centered.
