RE: MOKI RADIAL Care and Maintenence
Hi Eric, it's difficult to form a view from here but the ign unit is picking up power, solid green led, the other led should have five pulses per rev. Now there is a breakdown somewhere, check your low tension connections the multi plug to the ign unit, check the hall sensor pickup remove from engine and pass a magnet over it you should get one flash per pass. If all this checks out you probably have a faulty ignition unit...............hope this helps.
m
