RCU Forums - View Single Post - Throttle Spring vs Servo Current
Old 09-02-2012 | 03:33 PM
  #31
acerc's Avatar
acerc
Default RE: Throttle Spring vs Servo Current
Yes I use push rod's, that was my point. The gas carb's were not designed for push rod's, cable pull-spring return. Glow carbs are designed for rods not cable.
As for using a cable on a plane, why not? That's what the carb was designed for!
And I never said oneshouldn't cut the spring from the throttle arm. In my opinion that work's good.
