RCU Forums - View Single Post - COMP-ARF A-4 BUILD
Old 09-03-2012 | 05:06 AM
  #102
fred cesquim
Default RE: COMP-ARF A-4 BUILD
by pass and tailpiped done.
had to work a little on the back of air intakes(came misaligned)
made custom wood support for the tailpipe to hold it on the back fuselage on 2 points, later will attacj it to the bypass as well via 2 x 4 mm bolts on the underside of the bypass cover
ID:	1797873   Click image for larger version
ID:	1797874   Click image for larger version
