RCU Forums - View Single Post - Mold release removal
Old 09-03-2012 | 07:19 AM
frequent flyer's Avatar
frequent flyer
Default RE: Mold release removal
You use water to clean the part.<div>You must sand a new fiberglass part, 220 grit is best to ruff up the surface.</div><div>You must also use theproper primer.</div><div>If you can scratch the primer off with your fingernail it is not the right one for fiberglass.</div><div>A clean scuffed surface and the correct primer are essential for a successful paint job.</div>
