RE: Throttle Spring vs Servo Current
If you do not want to use the spring you can always take a drimmel with a cut off disc and just cut the U shape of the spring that feeds into the trottle arm off,, that way you will have no spring load at all but still have the spring in place to keep the tension on the butterfly assembly...</p>
