RCU Forums - View Single Post - Sig Koverall Application Process
Old 09-03-2012 | 03:54 PM
rlemaster's Avatar
rlemaster
Default RE: Sig Koverall Application Process
Hi Bob,
The Koverall is shrunk using heat from a heat-gun or iron. I generally seal / glue it around the edges then shrink it with a heat-gun, then dope the entire thing with a 50% dope 50% thinner mix. When you do that with something like a wing, the dope will bleed through and adhere to the ribs.
Russ
