RE: Pressure tap for Turbax1 ducted fan unit
I tried that once with a Byron setup. Disconnected it. It wasnt necessary, if I remember correctlt it used to flood my engines causing a to rich engine run. Does the pipe have the pressure fitting? It will be different i am sure for each fan and motor setup.
