http://www.rcgroups.com/forums/showthread.php?t=1363323
<span style="font-size: small">Title: Sorting out the different ESC brands
</span>cryhavoc38:
" ... The larger amp Jeti Spin's are manufactured by ZTW to Jeti specs ...".
"... I read a post(s) that a jeti/hacker fan completely wouldn't believe that these esc's were manufactured in China, but a side by side comparison of the Jeti/hacker Spin 99 Opto and the ZTW 100 Opto were identical with regards to physical components, board design and layout ..."</p>
cryhavoc38:
" ... ZTWOEM speed controllers, otherwise known as ZTW are found under MANY different brands but to name a couple:
Hacker X "pro"
Hacker/jeti Master spin (the larger ones like the 99 Opto). Not sure on ALL of them
SonicElectric
Older Hyperion esc's
Mystery Blue Board esc
The larger square shaped Electrifly esc's
The larger amp Jeti Spin's are manufactured by ZTW to Jeti specs. **
REVOXX ..."</p>
http://www.rcgroups.com/forums/showthread.php?t=1573179
alfabeast:
" ... Had the same issue with my ZTW 80 opto esc - which looks exactly like the Hacker's. I read that they make them for Hacker ..."</p>
