ORIGINAL: chrispol
I'm planning to build one of these and use my jetcentral Bee in it around 14.4lbs thrust or so anyone try the new generation with a smaller turbine?
I have a P-60 that produces 13LB of thrust and I asked Henry of Modellbau if I can put it on my V3 Tornado and his answer was yes and it will go faster than the V2 and V1 because of the cleaner lines. Though I guess with 13LB it'll be leaning more towards being under powered and will definitely require longer run way for take off and will have limited vertical so I am not going to use it. Give Henry a call it's worth it.
Azzam
