RCU Forums - View Single Post - TT .39 heli engine ruens glow plugs
Old 09-05-2012 | 08:10 AM
earlwb's Avatar
earlwb
Default RE: TT .39 heli engine ruens glow plugs
ORIGINAL: Basil Yousif
I have the Thunder Tiger .39 heli glow engine on a Raptor 30. The engine is starting to ruin glow plugs only after one flight. It also has a problem sucking in fuel while trying to start it.
Going back to the first post again. A problem sucking fuel implies a air leak somewhere. The O-ring under the carb is the first thing to check. You must push down on the carb hard to compress the O-ring a little before tightening up the screws or clamp. The next is the back plate might be loose. The head could be coming loose too. Then we get to the bearings, where the front bearing may not be sealing like it should leading to an airleak too. Then there is adjusting the engine to run too lean, heli engines tend to run a little more on the rich side than airplane engines do.
Of course we do not know what fuel the OP is using. Too much nitromethane can be a problem if the engine isn't set up for it.
Also what brand glow plug is the OP using. The wrong heat range plug can be a problem. Years ago I got a batch of defective major band name plugs too. I went through one flight per plug, I never bought any of those brand plugs since then.
