RE: Hobbykings Turnigy battery DX8 problem
I would guess that something else went wrong. Low voltage warning is 6.4 volts, so you still had plenty of voltage left. The screen on the DX8 shows the batt voltage as well as the pic of the batt. The reason it quit could be anything. A buddy had his quit about a week ago after he put a new switch in it. Found the connector on the new switch was bad and pulled out. The HK batt. has been in for about a yr. with no problems
