RE: Yak 54-Lanier 87
OK, that sounds pretty good, Probably end up about 25 to 30 degrees, and a little more on rudder. Like it a little more active, and triple rates will help..
Another question is this, There are four aileron servos, 2 per aileron, they are presently Y'ed together, and run on seperate 2 channels at receiver.
I think that they should all be on seperate channels, Run as four ailerons on seperate channels. As the ailerons are now, they buzz like crazy, ailerons seem to be a little twisted.
I can fix that, but I think things would be simpler with each aileron servo on a different channel, stops twist in the ail, and the servos would not buzz..Does that sound CORRECT?
