RE: Story of Two StuG's
Looking good. I have used that product also, uses an actual metal in the gray solution then you add the other solution to rust the metal flakes. I like how you can vary the effects by adding more or less. Also you really need to do that in a very well ventilated area, that is some nasty smelling stuff, which you already know. I read on the product it can cause kidney damage, if you inhale too much. But the results are nice.
Cheers
Wade
