ORIGINAL: airrds
Hi,
I am using a Jr 11x xmitter, and a JR 1221 powersafe with 4 sats.
thanks
I'm not a JR guy but I'm sure you can set up the two servo function and then use the extra channels to mix the extra servos to each of those Ail channels, just use prog. mix. You have the channels and a RX that can take the amps, got for it with what you have.
I'm sure some JR expert can talk you through the functions,, might try asking in the giant scale forums
good luck
