RE: Redcat Vortex SS
What you may find after break in, is the engine will comfortably "loosen up" then you may find that you will have to usually lean the HSN to get a good run. the HSN and the LSN do rely on each other for a perfectly set carb so adjust carefully and don't go too far on one and not the other.
