RE: Prop balancing.
Tacx that is fine if you never use engines with smaller shaft sizes say .20 and under or some electic props where the smallest taper of the cones is needed. Just turning one around is easy and just as effective Well that is untill your cone/wire set is so old and well used the cones slide to easily [X(]
John
