ORIGINAL: Mike2735
8Mills - Didn't mean to come off as upset. I was not in any way. I had just acknowledged the fact the I had it wrong.
The dimensions of my design might help: The rotors are 1 inch in diameter and 3 inches long. I have my blower pulley half the size of my crank pulley. That is why I said 2 to 1 ratio. I will change it to a 1 to 1 ratio. I also made it a twin carb setup to help with the leaning condition that will happen under boost. I plan to have an incremental throttle on the second carb that is adjustable.
I dont think you will have a problem with a lean condition under boost, but your carb idea is a good idea!
Thanks everybody for all their help and keep it coming.
