DBC3/TBS Mini Recoil Setup
I am just installing a DBC3/TBS Mini in my modified King Tiger. I was using a PICO switch on a DBC2 running from the Recoil output on the DBC2 to a modified HL recoil system and microswitch. It worked very well.
However, the DBC3 uses the Recoil output for the TBS Mini.
Any suggestions on how to setup the recoil system and still use the PICO switch and HL Recoil motor?
While I'm at it: I want to change the elevation from the HL elevation motor to a servo powered system. Has anyone used the additional servo lead from the DBC2/3 for this purpose?
Thanks for you help!
tjs
