RE: DBC3/TBS Mini Recoil Setup
I just sent you an email with a diagram for wiring up the recoil.
Elevation servo will be tricky. You have to run it from a stick that does not self center, and you would have to work around the DBC3 firing from the full up on the normal elevation stick. I live with the rotating cam as most time elvation in an IR battle is not that precise anyway.
I am testing other methods on my bench right now. The Benedini does have some servo control but the elevation is too darn slow using the benedini to control it.
Cheers
