RE: Twin .61 prop question
Thank you guys for all the input many thanks !!!!<div>
</div><div>Ok from reading the plans the engine mounts have the following angles -</div><div>
</div><div>Left engine has 1 degree left thrust.</div><div>
</div><div>Right engine has 4 degrees right thrust.</div><div>
</div><div>
</div><div>So to some up, i have too run engines in the same direction with the same props ? i have a pair of master airscrew 10x7 3 blades that i want too use.</div><div>
</div><div>Im going to match the rpms of the engines.</div><div>
</div><div>Many thanks</div><div>Will</div>
