RCU Forums - View Single Post - Ignition Module failure
Old 09-10-2012 | 03:23 AM
pe reivers
Default RE: Ignition Module failure
It all depends on how you tested the spark. Out of the engine, the spark should at least bridge a 6mm ( 1/4" ) gap. If not, the coil is too weak.
