As much as I am not a fan of too much folder structure I think A build section is warranted, but not lets turn around and make that into 6 other subcategories., ie Tamiya, Heng Long,WSN, Mato. Mattoro, Torro, etc.. Just a Build section period.
You guys realize file folder structure is old school. Meta data with and a good serch engine will find what you are looking for.
Take Google as an example. You type in what you want to look at, the more detail the better, and bam the files are there to look at. No searching through some file hieachy looking for things.. Anyone who had used central servers know no two humans think alike when it comes to where something should be filed, or how deep the folders should go.
I would sooner this forum spend the time updating their search engine., Tank Forum, E100, Mustclime should result in exacltly what I am looking for. I'll try it and see what happens.
Yes , Search engine Metadata needs work. The above resulted in nothing, and that is really the problem,
So yes until the serch engine is improved give us a folder!!!!!!!!!
Dan
