RCU Forums - View Single Post - Making a Good Landing
Old 09-10-2012 | 12:30 PM
  #78
billd76's Avatar
billd76
Default RE: Making a Good Landing
ORIGINAL: Simul8R
I am still in my early 2nd a/c (3rd actually - RIP 2nd) days. When I was flying my 2nd a/c which was a low wing trainer at a field with a very limited runway I had trouble as I was approaching too fast and had the pleasure of watching my flare use up all the available runway.<div>
</div><div>I was flying my circuits high because I just didn't trust the engine. At one point I had more deadstick landings on my plane than my glider and that takes some doing.</div><div>
</div><div>I slowed down, flying the approach at idle power, but then found that I was running out of energy in the flare and I made a lot of hard and bounced landings. That was when I started to learn to use just a little power into the flare. All of a sudden the plane greased nicely onto the ground.</div><div>
</div><div>Now I am flying at a larger field and with an OS 55AX engine on my a/c. The concern about the engine cutting out at any time and especially on a go-around is no longer preventing me from flying circuits at a better height. Approaching with power and just using a little blip power to arrest the descent instead of elevator is making all the difference. With the larger field I don't have to panic if I miss my touchdown point and with that comes the ability to get in more practice approaches.</div><div>
</div><div>This backs up what everyone has said. </div><div>
</div><div>Learn to use the power to fly a powered approach using the throttle to control descent, and flare, and not elevator and then just practice. Get out there at a time when there are not many others at the field and then you can just fly circuits and touch and goes for hours if necessary. Don't forget to fly the plane until it is static. I also find that rolling on the mains during the go around is a great practice for rudder control during the takeoff roll.</div><div>
</div><div>Just my 2c worth.</div>
Concur with all said here. Use the throttle and not the elevator for control. However your plane needs to be trimmed for level flight while up in the air at half throttle. Once properlly trimmed you should be able to use the throttle to control your alltitude when landing. If you use the elevator when landing (too much that is) the plane will almost always stall, primarily becuase you do not have enough speed to maintain altitude. Resulting of course in a crash. some of the lighter 3d planes will float right in, but even they will land super smooth with a touch and I mean just a touch or blip of throttle. When you U tube guys flying. listen to the throttle when that come in or when they are doing their tricks, throttle management is the key you just about all they do. Minn Flyer (God rest his soul) gave me the best advice I've ever got on landing. He told me to " learn to fly the plane 2 foot off the ground without landing using as much of the run way as you can" Once you can do that you can certainly land the plane.
