RCU Forums - View Single Post - CDI gr8flyer55
Old 09-11-2012 | 02:49 PM
  #241
jakestew
Default RE: CDI gr8flyer55
Release 12F683 v0.9b
New features...
-Multispark working!
-You can set the degrees between multisparks
-You can set the number of sparks for each mode - start, low RPM, and normal running
-You can set the MSD cutoff RPM for normal mode so that you aren't trying to multispark at high RPMs
Right-Click on the attachment link and choose "Save"
Then rename the file to: 12F683_v0.9b.zip
Extract the two files.
-Jake
P.S. COM,I sent you out the files. If anyone else is having problems let me know. The links seem to work for me.
EDIT: Old version removed, use newer version below.<br type="_moz" />
