RCU Forums - View Single Post - Setting motor position
Old 09-11-2012 | 04:19 PM
KitBuilder's Avatar
KitBuilder
Default RE: Setting motor position
That looks like its made for electric with that box mount setup. I would beef that up a bit if your able. Generally engines are mounted offset for right and downthrust and washers, etc.. as suggested are used to provide the correct angles if the firewall is not pre-angled which brings the nose of hte motor into alighnment with the cowl opening.
