RCU Forums - View Single Post - Setting motor position
Old 09-11-2012 | 06:36 PM
larrysogla
Default RE: Setting motor position
Yup.........that wood box motor mount sure looks like setup for an electric motor which produces less vibration than a glow motor. The KitBuilder is correct that the wood box motor mount needs to be beefed up/braced up with wood triangle stock glued with epoxy to the wood box motor mount at load bearing areas. 'Nuff said.
