RE: Leopard C2 Build thread
Thanks. Be aware that this tank has the whole fulcrum assembly fabricated, and I did not use the kit parts. You may be right in the fact that the gun shield is high, but if you are basing that on the kit then you may be in error, as I did something completely different then the kit instructions suggested. Pretty hard to tell in the photo's, but I will check it. Next time I have this turret apart I will look a little closer and look at lowering it slightly
Again thanks
