RCU Forums - View Single Post - Servo flutter
Old 09-12-2012 | 07:30 AM
raptureboy's Avatar
raptureboy
Default RE: Servo flutter
Technically it's not flutter, flutter happens while the plane is in flight.Just being a wise guy. But I have has the same problem and traced it to a bad y. You could do as suggested an hook it up to seperate channels but you will have to label them left and right or you will be backwards if you plug them in wrong.
