RCU Forums - View Single Post - weight to power ratio / which engine
Old 09-12-2012 | 09:40 PM
rangerfredbob
My Feedback: (13)
Default RE: weight to power ratio / which engine
ORIGINAL: av8tor1977
I don't recommend the Weedeater/small Poulan engines as they are low on power and cheaply made in my opinion. From there you go up to the Stihls, Echos, etc., but the price goes up and the availablity used goes way down.
AV8TOR
I wouldn't seek them out either, but since they're the only thing Walmart sold for YEARS, there's TONS of them out there, I agree on the quality and such though, the 2 bolt backplate engines are nicer than the 4 bolt ones though, the only gasket on those is for the carb, the rest are formed rubber O ring type seals.
Anyway, with oddy's altitude and keeping the current plane flying, putting the engine on a diet or getting a lighter/larger engine would be the best bet, I'm sure there's some weight to loose somewhere, I know my McCulloch 32 has some to loose but most of it's weight is in the crankshaft... Have ideas but the plane flies almost perfectly how it is
