RCU Forums - View Single Post - Servo flutter
Old 09-13-2012 | 08:03 AM
Gray Beard
My Feedback: (-1)
Default RE: Servo flutter
ORIGINAL: devil505
I took everyones advice and set the plane up for aileron mixing. It appears the problem was in the Y cable. I also swapped out the crystal I the crystal. No problems now except for having 3 servos I have to plug in on the wing. I used colored page tabs to label the ends so they are easy to connect.
Did you break out a sweat with all that hard work??? The only servo leads I use are two {usually} short ones I leave in my RX for the ailerons so I'm not plugging in and out my aileron leads into the RX. The leads can also cause problems so I just cut and splice extension wire into my servos requiring an extension. By soldering in the extensions I never have a lead corrision problem. I'm really lazy and don't want to be pulling leads and cleaning them. Takes me a while to solder in the extensions but once done I can forget about them.
Glad that solved your problem. Pointing out the Y is easy, they tend to cause problems like that very often.
