ORIGINAL: Thiagooo
<span id="result_box" lang="en"><span class="hps">Anyone know</span> <span class="hps">what</span> <span class="hps">this noise</span> <span class="hps">might</span> <span class="hps">be</span><span>?</span>
<span class="hps">I opened</span> <span class="hps">that box</span> <span class="hps">and</span> <span class="hps">everything</span> <span class="hps">ok</span> <span class="hps">ta</span> <span class="hps">...</span> <span class="hps">also</span> <span class="hps">open</span> <span class="hps">that part</span> <span class="hps">smaller,</span> <span class="hps">and</span> <span class="hps">everything is</span> <span class="hps">right with</span> <span class="hps">the gears</span><span>,</span> <span class="hps">but</span> <span class="hps">doing</span> <span class="hps">this</span> <span class="hps">weird noise</span> <span class="hps">...</span>
<span class="hps">This is the</span> <span class="hps">rear differential</span><span>.</span>
<span class="hps">The</span> <span class="hps">front</span> <span class="hps">works without</span> <span class="hps">noise.</span>
<span class="hps">This</span> <span class="hps">Dogbones</span> <span class="hps">without</span> <span class="hps">connecting</span> <span class="hps">to the engine</span><span>, I</span> <span class="hps">also</span> <span class="hps">pulled</span> <span class="hps">the engine</span> <span class="hps">...</span> <span class="hps">finally</span><span>.</span> <span class="hps">this</span> <span class="hps">light and loose</span><span>.
[youtube]8phhJy8N1lo[/youtube]
http://www.youtube.com/watch?v=8phhJy8N1lo
</span></span>
Pull the diff apart. I didn't watch the video, but if anyhting makes a noice that's not natural, pull it apart. Mine makes a clicking sound. So I took the rear diff apart and found a missing tooth on the ring/bevel gear.
