ORIGINAL: Junior55
Hi all i'm look for the nose canapy for the 95'' B-25 if any body have one. i'll buy it and a main strud for it. this parts are back order form troybuild for a few weeks. p.s if anything thank you all jr.
Century Jet Models had been making a very nice nose canopy (i.e. forward gunner position) for the ESM B-25. I bought one for $30, made from much thicker & better material, doesn't crack when you touch it :-). You may have to call them to order this.
As for a main strut??? I assume you bent one on landing??? Overall, I found the original ESM gear to be junk. Worked OK for a while, but made from way too soft aluminum. I use Robart gear in mine and Century Jet makes a set that will just drop in. The Robart get I have required modification of the ply mounts ... but it is the toughest gear!
