RCU Forums - View Single Post - Propeller Question
Old 09-13-2012 | 03:51 PM
acdii
Default RE: Propeller Question
The wood should be of a tight grain, usually maple or hickory. The grain should be as straight as possible with no knots.  You want to avoid having gain run cross wise on the prop and should run the entire length.
Too bad you cant use a variable pitch prop, so you can increase thrust on take off, and trim it for best flight.
