RE: STRETCHING A HULL...IS IT POSSIBLE ??? Old Graupner Systems Cat build
lol its so crazy here at this site...hardly anyone has any idea's...or help with fiber-glassing...68 views in 1 day and only one guy bothered to respond..I cant be the only one playing about creating stuff ??
Once i've cut the Hull where needed, what would you suggest doing to keep the parts straight ? maybe i should glass it on the whole exterior to hold it in place.. ? or balsa rib it then fill in with abs sheet's, or sheet balsa the exterior then abs the gap ? using little filler, sand smooth, then gel coat and she's ready for the fiber..?
Im thinking of a scale version of the SIMAC REPORTER Cat, and it will be like real...with two stingers and two motors, the motors will be something like Leopard 2200kv..there about $75 each......this old Cat will fly when finished..
