ORIGINAL: EHFAI
The resolution of the ET GPS appears good enough (usually using 9 sats). For example, one can easily determine "roundness" of rolling circles (or 8's) as well as size, as these are in a horizontal plane.
Vertical maneuvers are more difficult, some of which lies with the ET viewer. The data are compiled so as to present a track relative to time and we fly a sequence in the same space (box). Sothe track of each maneuver overlays the previous -it ends up looking like chicken scratch. That means each maneuver (or a couple at most) must be done individually, which is very time consuming.
Some work has been done to translate the data into a 3D "box" which would allow an entire sequence to be scrolled through on a maneuver by maneuver basis referencing the time base. It would also be possible to look at a maneuver from various viewpoints. I'll let the persons working on this to comment further if they wish - but work in progress.
Another trick that might work is to switch the logger off/on in flight(which starts a new data group) to limit the overlaying of maneuvers during a sequence - haven't tried that yet.
I've been dreaming about having GPS record the flight and then play it back in 3D for a long time. I look forward to updates! What would be even better is if you could mount an instrument to track the aircraft attitude and then have a virtual playback of the track and attitude of the airplane to look at wings level, etc.
I keep track of my distance (and wings level status, elev and rudd inputs) by mounting a small camera behind the canopy as in this
old clip. It's easy then to x-reference google maps. I'm a beginner, and what I notice is that my distance is greatly influenced by wind direction. With my little plane, I have logged distances of 120 - 180m over several flights this summer practicing 402. I can see how 175+ would be easy to bust with a 2 meter plane!
Bill Polits
D7
